Remove Items From Selection Set
kunekainen
Hi there. I am about to complete my first code for AutoCAD VBA and I have a problem which I couldn't solve it for hours.
This is my code:
Public Function NumericOnly(s As String) As String
   Dim s2 As String
   Dim replace_hyphen As String
   replace_hyphen = " "
   Static re As RegExp
   If re Is Nothing Then Set re = New RegExp
   re.IgnoreCase = True
   re.Global = True
   re.Pattern = "[^0-9 ^x ^~]" 'includes space, if you want to exclude space "[^0-9]"
   s2 = re.Replace(s, replace_hyphen)
   re.Pattern = "^\s+"
   s2 = re.Replace(s2, vbNullString)
   re.Pattern = " \s+"
   NumericOnly = re.Replace(s2, replace_hyphen)
End Function
Sub bqtable()
Dim varPt1 As Variant
Dim acTable As AcadTable
Dim ss As AcadSelectionSet
Dim rawtxt As AcadText
Dim temptxt As String
Dim i, j As Integer
Dim x, y As Integer
Const PI As Double = 3.14159
Dim tempdia As Integer
Dim checkerdia As Boolean
Dim weightdia As Double
Dim totalweight As Double
Dim weight As Double
'Load Form
'mainGUI.show
defaultrowh = mainGUI.TextBox2.Text
'create table
varPt1 = ThisDrawing.Utility.GetPoint(, "Select Point")
Set acTable = ThisDrawing.ActiveLayout.Block.AddTable(varPt1, 3, 5, defaultrowh, 30)
acTable.SetText 0, 0, "DONATI METRAJI"
acTable.SetText 1, 0, "Adet"
acTable.SetText 1, 1, "Çap"
acTable.SetText 1, 2, "Boy"
acTable.SetText 1, 3, "Benzer"
acTable.SetText 1, 4, "Agirlik"
'tabloyu doldur
Set ss = ThisDrawing.SelectionSets.Add("SS047")
ss.SelectOnScreen
i = 2
j = 0
weightthin = 0
weightthick = 0
totalweight = 0
For tempdia = 8 To 34 Step 2
checkerdia = False
weightdia = 0
       For Each rawtxt In ss
               temptxt = rawtxt.TextString
               'Büyük Harfe Çevir ve Çap Operatörünü Düzenle
               temptxt = Trim(UCase(Replace(temptxt, mainGUI.TextBox1.Text, "ƒ")))
               '/ Varsa Temizle
               If InStr(temptxt, "/") <> 0 Then
                           pos0 = InStr(temptxt, "/")
                           pos1 = InStr(temptxt, "L=")
                           x = pos1 - pos0
                           temptxt = Trim(UCase(Left(temptxt, pos0 - 1) & " L=" & Right(temptxt, Len(temptxt) - pos0 - pos1 + pos0 - 1))) & " "
                   Else
                           temptxt = UCase(temptxt) & " "
               End If
               'Sayıları al ve yazdır
               A = NumericOnly(temptxt)
               Arr = Split(A, " ")
               If Arr(1) = tempdia Then
                   checkerdia = True
                   t = 0
                   Do While t <= UBound(Arr)
                       acTable.SetText i, t, Arr(t)
                       t = t + 1
                   Loop
                   acTable.SetText i, 3, "1"
                   'Mevcut poz için ağırlık hesapla yaz
                   weight = acTable.GetText(i, 0) * PI * (acTable.GetText(i, 1) / 1000) ^ 2 / 4 * acTable.GetText(i, 2) / 100 * acTable.GetText(i, 3) * 7850
                   acTable.SetText i, 4, weight
                   acTable.SetText i, 4, Format(acTable.GetText(i, 4), "#0.0")
                   acTable.SetRowHeight i, defaultrowh
                   acTable.InsertRows i + 1, defaultrowh, 1
                   'ağırlık güncelle
                   If tempdia = 8 Or tempdia = 10 Or tempdia = 12 Then
                       weightthin = weightthin + weight
                   End If
                   weightdia = weightdia + weight
                   totalweight = totalweight + weight
                   'işlenen datayı selection setden çıkar
                   ss.RemoveItems (rawtxt)
                   i = i + 1
               End If
       Next
       'Bakılan çap varsa toplam ekle
       If checkerdia = True Then
           acTable.SetText i, 0, ("Toplam ø" & tempdia)
           acTable.SetText i, 4, weightdia
           acTable.MergeCells i, i, 0, 3
           acTable.SetCellAlignment i, 0, acMiddleLeft
           i = i + 1
       End If
Next
ss.Delete
End Sub
The problem is:
I want the processed item removed from the selection set but I couldn't manage it.
Thanks in advance.
RemoveItems requires an array of AcadEntity elements. Even if there has to be only one element in it.
So you must add something like what follows:
Dim Ent(0) As AcadEntity ' this you can add at the beginning of your code toghether wit other Dim statements
Set Ent(0) = rawTxt 'this line must be added before the following one
ss.RemoveItems Ent ' this line you already have in your code
  • 5 years later...
