Add a fixed point
mhmnibras
"(defun c:xy()
(command "setvar" "dimzin" 0)
(setq ucsname (getstring "\nPlease enter the current ucs name: "))
(command "ucs" "restore" ucsname)
(setq e (entsel "\nPlease choose an object: "))
(setq pt1 (getpoint "\nplease locate point for Y:"))
(setq dy1 (cadr pt1))
(setq pt2 (getpoint "\nplease locate point for X:"))
(setq dy2 (cadr pt2))
(setq e (entget (car e)))
(foreach f e
(if (= (car f) 10)
(setq g (list (cadr f) (caddr f)))
(setq g (trans g 0 1))
(setq x (car g))
(setq xabs (sqrt (* x x)))
(setq y (cadr g))
(setq yabs (sqrt (* y y)))
(setq pty (list (- x 0.03) (+ dy1 0.015)))
(setq ch (rtos yabs 2 3))
(command "text" pty 90 ch)
(setq ptx (list (- x 0.03) (+ dy2 0.04)))
(setq ch (rtos xabs 2 3))
(command "text" ptx 90 ch)
(command "line" g (list x dy1) "")
in this code no need getpoint
i need to add a fix coordinate from the ucs point for x axis and y axis
plz help me any one...
To retrive the value of Y coordinates instead of points, just replace this piece of code:
with this:
(if (or (not (setq e (entsel "\nPlease choose an object: ")))
       (not (setq dy1 (getreal "\nFirst Y coordinate:")))
       (not (setq dy2 (getreal "\nSecond Y coordinate:"))))
(exit)
