issammesk Posted September 8, 2014 Share Posted September 8, 2014 hi all please i ask bout zoom object if we have way or lsp to zoom exatlly as object example when i put regtangle as object then when i want to make view port i select regtangle i want to give exactlly view port as regtagle Quote Link to comment Share on other sites More sharing options...
MSasu Posted September 8, 2014 Share Posted September 8, 2014 There is already the Object option in ZOOM command. However, due to the ratio of your display, the result may not be an exact fit. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted September 8, 2014 Share Posted September 8, 2014 Type ZOOM then O ( stands for Object ) eg. Command: Z ZOOM Specify corner of window, enter a scale factor (nX or nXP), or [All/Center/Dynamic/Extents/Previous/Scale/Window/Object] : O Select objects: 1 found Quote Link to comment Share on other sites More sharing options...
issammesk Posted September 8, 2014 Author Share Posted September 8, 2014 thank sir but small explain when i go to layout and make viewport for same regtangle in model and zoom object for this regtangle it give me zoom but not excatlly i mean i want zoom in view port the upper point in reg. and bottom point for reg.) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted September 8, 2014 Share Posted September 8, 2014 Double click inside the viewport then use the zoom command as explained earlier then double click outside the viewport to exit the viewport . If viewport is not suit the rectangle size , just adjust the viewport by selecting it and relocate its coordinate points . Quote Link to comment Share on other sites More sharing options...
ayethzerothree Posted September 17, 2014 Share Posted September 17, 2014 Double click inside the viewport then use the zoom command then, click control key together with the right click on your mouse to prompt you in snap option, click the enpoint then click on one corner of your rectangle, do it again and click on the other corner of your rectangle and then thats it. Quote Link to comment Share on other sites More sharing options...
issammesk Posted September 17, 2014 Author Share Posted September 17, 2014 thank you sir i will doit:) Quote Link to comment Share on other sites More sharing options...
