Results 1 to 5 of 5
    Full Member The_SuperVixen's Avatar
    MEP 2011
    Jun 2010
    NYC
    30
    Default Exporting/Importing Profiles
    Please Help.
    We're planning on upgrading from MEP 2013 to MEP 2015. We have a custom Ribbon, containing custom programs and also a bunch of Custom Tool Palettes. These are all saved on a network and have all been created by different people over the years, who of course are no longer here.
    I've got everything setup on my machine so it all works. I export my profile, save it to a network location, then import it on another user's machine. It doesn't work completely.
    The ribbons disappear, I switch to a different workspace, and that brings back the ribbons, but the custom programs, on our custom ribbon don't work.
    I was told to copy over the "Profile.aws" file saved locally on my machine (C:\Users\*username*\AppData\Roaming\Autodesk\MEP 2015\enu\Support\Profiles) and overwrite the same file on the user's local drive, but that doesn't seem to do it either.
    I am admittedly not familiar with editing cuix files. To load the Ribbon I do load a specific cuix file from the network. I'm assuming its something to do with this, but through my research, I haven't had much luck figuring it out. I tried saving my current cuix file to the network and loading this on the user's end, doesn't work either.
    I have gotten it to work by editing the Support File Search Path in Options manually first, and then loading the profile, but everyone seems to believe there's no need to have to do this for every user in the office, and our satellite offices. Are they right? What am I doing wrong?
    Thanks in advance!
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,713
    Try this start default MEP with a default profile then load your profile make it current, exit autocad make sure you EXIT!!!! not crash out using the red X.
    Ok copy the desktop icon and edit the properties and put your profile in the last bit look for /p yours should be /p yourprofilename. This works for Autocad not sure MEP.
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    1+... Manually importing a Profile in-session is not the same as launching application with the desired Profile, as Bigal touched on.
    You'll want to familiarize yourself with AutoCAD's Startup Switches... Yes, you're using MEP, but that is a vertical that sits on top of vanilla AutoCAD, so the same product functionality applies... Then, setup a custom application icon, with the appropriate switches in Target Property.
    Please also note, that specifying the file path and file name of your profile saved to network location via /P switch in application icon's Target Property will only 'load' the Profile if it does not already exist, and simply sets it as active profile when launching from said application icon. If Profile already exists, and is different than that which is stored on the network, the local version that already exists in Registry will be take precedence. To fix, you'll have to delete the current version, and then re-launch, which will re-import - hope that makes sense.
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    MEP 2011
    Jun 2010
    NYC
    30
    Quote Originally Posted by BIGAL View Post
    Thanks, this seems to work.
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,713
    No worries we have spent lots of time working out how to do simply.
  1. Replies: 7
    Last Post: 18th Aug 2014, 03:34 pm
  2. importing molding profiles into AutoCAD
    By Timothyl in forum AutoCAD Beginners' Area
    Last Post: 30th Apr 2011, 11:06 pm
  3. Exporting User Profiles
    By Mark1965 in forum AutoCAD General
    Last Post: 20th Jan 2010, 03:30 pm
  4. Exporting and Importing Profiles Autocad 2007
    By GibraltarDesign in forum AutoCAD General
    Last Post: 16th Jan 2009, 10:20 pm
  5. importing user profiles from acad2002 to acad 2004 lt
    By xavier in forum AutoCAD Drawing Management & Output
    Last Post: 8th Jan 2005, 01:31 am
