Damon :) Posted September 9, 2014 Share Posted September 9, 2014 I am new to the whole CAD experience, how do I add width or thickness to a circle? Thanks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 9, 2014 Share Posted September 9, 2014 You don't. Use the DONUT command instead unless of course you want to use a custom lisp routine to do the job for you. Circle on left has an O.D. of 2 units. Donut on right has an I.D. of 1.8 units and an O.D. of 2 units. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 9, 2014 Share Posted September 9, 2014 Re: Thickness. Be careful with this as AutoCAD construes thickness to mean height. See what happens when THICKNESS is changed from its default. The circle to the left has a "0" thickness (the default setting); the one to the right has a 0.25 thickness. Quote Link to comment Share on other sites More sharing options...
Damon :) Posted September 9, 2014 Author Share Posted September 9, 2014 Thank you:D Quote Link to comment Share on other sites More sharing options...
Dazacad Posted September 10, 2014 Share Posted September 10, 2014 See this tip. http://www.cadtutor.net/forum/showthread.php?24924-Adding-global-width-to-a-circle Start by making a polygon with 4 sides. Check inscribed in circle when prompted. Next specify your radius. That will create a square. Then select polyline edit, then select fit, then width. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 10, 2014 Share Posted September 10, 2014 Daz: Just how does one control the radius of a circle drawn in this manner (derived from a "fitted" polyline)? Try it (the Polygon method) using 1" as the radius. After doing a PEdit > Fit what is the radius of the circle that has been created? Quote Link to comment Share on other sites More sharing options...
Dazacad Posted September 11, 2014 Share Posted September 11, 2014 Remark, I got a radius of 1". You don't actually get a circle as it's a 2d polyline or just a 4 arcs joined together. If you want to increase the size, you can use the offset command. I've never needed this to be accurate as I only use it to create blocks such as a circle with an attribute inside, so near enough was good enough. Quote Link to comment Share on other sites More sharing options...
