Incoming Files Activate Unwanted Sheet Manager Pop up.
muck
I am receiving a group of drawing files that seem to want to activate SSM pop up.
Is there an way to make these file not activate SSM pop up.
I can set SSMAUTOPEN and SSLOCATE to 0 but that that does not prevent
SSM pop up from pop up when I send drawings to other people in my
company. They don't like SSM pop up and I need a way to prevent
SSM pop up on the files I work on and receive.
Thank you,
Both SSLOCATE, and SSMAUTOOPEN are saved to Registry, so if you're setting those to 0, and SSM continues to open, then perhaps your settings are being modified at drawing open via AcadDoc.lsp, etc.?
Perhaps a hack of a workaround would be to add an expression to AcadDoc.lsp that checks for SSMSTATE == 1, and then invokes the SSMCLOSE Command.
