Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2015
    Sep 2014
    2
    Default Problem with OSNAP to tangent
    Hi, I'm having a problem with OSNAP and am not sure what I'm doing wrong. As you can see from the attached photo, I am using offset to create a parallel line to the one selected (the leftmost line) that I am trying to place tangent to the circle in the center. However, the tangent snap points (which should be visible in the picture) aren't working properly and cause the line to snap to a position inside the circle rather than tangent to it.
    My command process is offset -> through -> select line -> select TAN onsnap option -> hover over circle near desired tangent point.
    Any help would be appreciated. Thanks!
    Forum Newbie
    AutoCAD 2015
    Sep 2014
    2
    I figured out a different way to do this by creating a perpendicular line from the original line to the center of the circle to find the snap point for the offset line, which solves the immediate problem, but I would still appreciate advice on what I was doing wrong with the tangent feature or if the program doesn't allow me to use offset and tangent in that manner
    Forum Newbie
    not applicable
    Jun 2014
    4
    not sure if this answers the question, but two options:
    set UCS to line, use Quadrant snap on circle
    or
    draw XLINE and use tangent snap on two circles to hit the one spot that works (there are really 4 possible tangent lines between any two circles)
    Dan
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,083
    Sometimes the OSNAPS don't work as you want them to.
    For example, if you break your target circle, so that it becomes an arc, then you could use the Perpendicular osnap to offset through.
    Curiously, that technique does not work to a circle.
  5. #5
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,091
    Try using the perpendicular OSNAP picking the line first and then the circle (also perp). I only did a quick test but it worked on a sample I tried
  6. #6
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    AutoCAD is finding a tangent point in relation to some point on the original line. I'm guessing it is the point where you picked the line. There isn't a way to tell AutoCAD that you want the copy of your line to be tangent to the circle. As you figured out, a little simple geometry solves it for you.
    Drafting is a breeze.
  1. Tangent line problem
    By metsj373 in forum AutoCAD Beginners' Area
    Last Post: 30th Sep 2011, 01:24 pm
  2. Tangent to circle problem
    By clemson77on in forum AutoCAD General
    Last Post: 7th Dec 2009, 03:12 am
  3. Problem Snapping To Tangent
    By samson in forum AutoCAD Beginners' Area
    Last Post: 30th Jan 2009, 04:57 pm
  4. Problem Understanding Tangent
    By Problem_with_CAD in forum AutoCAD Drawing Management & Output
    Last Post: 13th Aug 2007, 10:12 pm
  5. osnap's problem
    By j_r_auden in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Dec 2004, 09:18 am
Tags for this Thread
