Results 1 to 3 of 3
    Forum Newbie hoky's Avatar
    AutoCAD 2013
    Sep 2014
    2
    Default Alignment point acquisition
    Hello there, I'm using Auto CAD 2013.
    When i draft on large drawings with a lot of objects sometimes is hard for me to pick/track points automatically. I'm wondering if it's possible to shift between AUTOMATIC and MANUAL point acquisition while drawing without entering options (temporary disable automatic acquisition)? is there a shortcut?
    Thank you in advance...
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor. You should try turning on SELECTION CYCLING, (CTRL+W) it will help you distinguish between objects which are on top of one another, or close together. If you right click on the icon in the status bar or in Drafting Settings you can select default behavior. It can be either static or cursor following, I prefer being able to see the list display.
    AutoCAD 2013
    Sep 2014
    2
    Default Acquired track points
    Thank you for your quick response . Do you know if it's possible to somehow maintain acquired track points when you zoom in or out?
  1. Alignment parameter as insertion point?
    By dsibbo in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Apr 2014, 02:45 pm
  2. Replies: 6
    Last Post: 11th Sep 2012, 08:20 pm
  3. Station from Alignment into a User Defined Property (in a point).
    By Bill_Myron in forum .NET, ObjectARX & VBA
    Last Post: 10th Apr 2012, 04:19 am
  4. text alignment point question rephrased
    By TroutKing in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Dec 2009, 03:46 pm
  5. tag string vs. alignment point question
    Last Post: 30th Nov 2009, 05:09 pm
Tags for this Thread
