Filribeiro Posted September 12, 2014 Share Posted September 12, 2014 Hi, I have a problem with a dynamic block that i tried to describe in the following video: https://www.screenr.com/UzrN Find attached the file with the dynamic block. Thanks in advance! Dblock.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 12, 2014 Share Posted September 12, 2014 The block works as it should, I think the problem is that you need to redesign how it should work. I added a line at the base point of the block to show the problem. you cannot stretch the linear parameter to less than zero, so although your visibility grip moves as you want, the base point will stay at the insertion point and at some stage this becomes the left most or right most point and you cannot go less than that. Hard to describe but try the block, you can't stretch the right side to the left of that vertical line, or the left side to the right. Dblock.dwg Quote Link to comment Share on other sites More sharing options...
Filribeiro Posted September 12, 2014 Author Share Posted September 12, 2014 Thank you Steven. I have solved the problem including the dimensions in the stretch entities so they can be also adjusted in the stretching process. Find attached the working block. Cheers! DblockV2.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 12, 2014 Share Posted September 12, 2014 That did it Quote Link to comment Share on other sites More sharing options...
