Behemothrex Posted September 16, 2014 Share Posted September 16, 2014 Hey guys, Well its been a while since I posted, but that's a good thing, as I have been progressing in my AutoCad adventure without to many problems. But this semester I have run into a problem that I have yet to overcome. So assistance would be appreciated. The trouble I am having is finding the centers of some of the circles I need to place to create the different curves that I need to complete the drawing. I have highlighted the area in question in yellow. Now a few of the circles are dimensioned on the drawing and they are easy to plot out, but for the life of me I cannot figure out how they are placing the other circles. Specifically the circles with the radii of 1.63, 1.98, 1.13 and the one on the outside of 1.25. Any thoughts would be appreciated. I have included the original and what I have completed so far. Thanks DGM - Problem 5-11.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 16, 2014 Share Posted September 16, 2014 TTR will be your best friend. Quote Link to comment Share on other sites More sharing options...
rkent Posted September 16, 2014 Share Posted September 16, 2014 You will want to use the FILLET command on this, establish the center lines where you can, draw arcs and finally fillet them together. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 16, 2014 Share Posted September 16, 2014 This is how I started out. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 16, 2014 Share Posted September 16, 2014 Trim it up Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 16, 2014 Share Posted September 16, 2014 Add the fillet Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 16, 2014 Share Posted September 16, 2014 Add the R1.63 (and R.25) Quote Link to comment Share on other sites More sharing options...
nestly Posted September 16, 2014 Share Posted September 16, 2014 Either CIRCLE>TTR with a radius of 1.13 or FILLET with 1.13 radius between the 4.18 dia arc and the 0.75 circle will establish the centerpoint in question Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 16, 2014 Share Posted September 16, 2014 Add the 1.25 Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 16, 2014 Share Posted September 16, 2014 Next step Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 16, 2014 Share Posted September 16, 2014 Trim and add another fillet So on and so on.... step-by-step... Quote Link to comment Share on other sites More sharing options...
Behemothrex Posted September 16, 2014 Author Share Posted September 16, 2014 As always you guys are fast and on the ball, but the main issue I am having is the placement of the initial circle with the radius of 1.13. How did you find that center? Am I missing a dimension someplace? Thanks Quote Link to comment Share on other sites More sharing options...
nestly Posted September 17, 2014 Share Posted September 17, 2014 Since you know the center of the 1.13 circle is 1.13 from the 0.75 circle and you also know that it's 1.13 from the 4.18 circle, some of the options to establish the center are: 1) Use the FILLET command to create a 1.13 fillet between the 0.75 circle and the 4.18 circle. The center of the FILLET is the point you are trying to establish. or 2) Use the CIRCLE command with the TTR (Tangent/Tangent/Radius) option to create 1.13R circle that is tangent to the 0.75 circle and the 4.18 circle (as shown in the animation in post #8 ) or 3) OFFSET the 0.75 circle 1.13 units toward the outside, and OFFSET the 4.18 circle 1.13 units towards the inside. The intersection of the offsets is the center. Quote Link to comment Share on other sites More sharing options...
Behemothrex Posted September 17, 2014 Author Share Posted September 17, 2014 Hey thanks nestly, guess I sort of overlooked that animation, duh. I have used the TTR many times before but I guess I was just baffled by all the circles I had drawn that still needed trimming, it was making things way too complicated. Its great to see other peoples thought processes to the same problem. The way JD started the drawing is completely different than the way I did and made the curves much easier to visualize. Once again its great to have the input of people that have been doing this for a while. That's the one downfall of Online school, its very hard to see how others would do the same problem. Thanks again! Quote Link to comment Share on other sites More sharing options...
