vin_578 Posted September 17, 2014 Share Posted September 17, 2014 Hello.. I have drawings created in autocad version. We create same drawings with different dimensions for blisters. Internal ratio of the dimensions remains same. I want to create template in autocad or want to use any other software where with the help of length,width and height which will calculate internal dimensions and will provide the similar drawings. I want to do this to reduce timing of similar drawings. Please help. Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 17, 2014 Share Posted September 17, 2014 It would be easier to see what you would like to do, if you could post a copy of a DWG or a couple of them, to see what things need to change between drawings Quote Link to comment Share on other sites More sharing options...
hoss Posted September 17, 2014 Share Posted September 17, 2014 Hello.. Internal ratio of the dimensions remains same. Why not scale the drawing using reference option Quote Link to comment Share on other sites More sharing options...
rkent Posted September 17, 2014 Share Posted September 17, 2014 Inventor would be your best bet in Autodesk products. Or Solidworks, Solid Edge, other true 3D programs. Quote Link to comment Share on other sites More sharing options...
