dil45 Posted September 17, 2014 Share Posted September 17, 2014 Hi All. i have recently buy Asus N550JK CM316H (16 gb Ram,4 GB Geforce dedicated Graphic,Core i7,2.50GHZ,1 TB Hard,Win 8.1 64bit). After purchasing i had to intalled some Softwares but some application were not running well,then i Refresh my PC and install agin softwares now every thing is sported but some softwares (Civil 3D,3D Max) is running slow. Kindly Help me is anay body has solution to make my applications running fast. THX, Dilshad Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 17, 2014 Share Posted September 17, 2014 dil45: You should have started a new thread. This one is five years old. Is hardware acceleration enabled in Civil? Quote Link to comment Share on other sites More sharing options...
dil45 Posted September 17, 2014 Author Share Posted September 17, 2014 How to Enabled acceleration? Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 17, 2014 Share Posted September 17, 2014 In plain AutoCAD it is via the 3DCONFIG command. Not sure if the command is the same for Civil 3D. Quote Link to comment Share on other sites More sharing options...
dil45 Posted September 17, 2014 Author Share Posted September 17, 2014 in civil 3d acceleration is Enabled (Option>System>Graphic Performance) but have still problem. Effects: ACAD_LineSmoothing supported turned on ACAD_PerPixelLighting supported turned on ACAD_AdvancedMaterial supported turned on ACAD_FullShadows supported turned on ACAD_TextureCompression supported turned off Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 17, 2014 Share Posted September 17, 2014 Do you have the latest drivers installed for your graphics card? Did you disable the InfoCenter (also referred to as the CommCntr)? Is this a standalone computer or are you working off a network? Quote Link to comment Share on other sites More sharing options...
dil45 Posted September 17, 2014 Author Share Posted September 17, 2014 Yes i have the Latest Graphic Card Driver installed and in using Standalone, i did not disable infocentre Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 17, 2014 Share Posted September 17, 2014 i have recently buy Asus N550JK CM316H (16 gb Ram,4 GB Geforce dedicated Graphic,Core i7,2.50GHZ,1 TB Hard,Win 8.1 64bit). After purchasing i had to intalled some Softwares but some application were not running well,then i Refresh my PC and install agin softwares now every thing is sported but some softwares (Civil 3D,3D Max) is running slow. What do you consider to be slow performance? What are you doing when the slow down occurs and what is happening on screen? What sort of files are you working on? Filesize? Complexity? Your computer specs appear to be more than good enough for running 3ds Max, so I'm not sure why you're having difficulty? Are you trying to work on huge models with millions of polygons? Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted September 18, 2014 Share Posted September 18, 2014 Do you have a model on the video card? or a clock speed. Sometimes some cards have overclocked speeds and can become unstable. Most that come with a default overclock setting have a small switch close to the input power cables. Also, as awful as this sounds, the computer itself could just be faulty in some way. Quote Link to comment Share on other sites More sharing options...
dil45 Posted September 20, 2014 Author Share Posted September 20, 2014 its normal work like Cross sections,Volume calculation,corridors. During working feel sleepy because my cursor works slow Zoom in/Out Slecting items /copy/move Editing etc. All other software's are working well. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 20, 2014 Share Posted September 20, 2014 You artfully avoided answering a handful of questions put to you so unless we start getting some answers it will be difficult if not impossible to provide further help. And while you are at it, disable the InfoCenter too then get back to us. Quote Link to comment Share on other sites More sharing options...
dil45 Posted September 20, 2014 Author Share Posted September 20, 2014 Now i have to disable InfoCenter,Durrinf working the cursor performence is slow like sleepy. Quote Link to comment Share on other sites More sharing options...
dil45 Posted September 20, 2014 Author Share Posted September 20, 2014 Driver Detail. Nvdia Geforce GTX 850m Driver Version=340.52 Direct 3D Api Version=11.1 CUDA Core=640 Graphic Clock=901 MHz Memory Data Rate=200 MHz Memory Interface=128-bit Memory Bandwiyh=32.03 total available graphic memory=12229 MB Dedicated Video memory=4.96 mB DDR3 Shared system memory=8133 MB video Bios Version=82.07.2A.00.02 Bus=PCI Express x16 Gen3 Device ID=10DE 1391 11CD1043 PArt Number=27030010 Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 20, 2014 Share Posted September 20, 2014 Please answer the questions Cad64 and Mike_Taylor asked previously too. Sloooooooooooowly, ever so slooooooooowly we'll get there. Quote Link to comment Share on other sites More sharing options...
dil45 Posted September 21, 2014 Author Share Posted September 21, 2014 Now i have solve the problen that was facing since few days. I was due to Power Sawing/Balence. Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted September 22, 2014 Share Posted September 22, 2014 Glad to hear you fixed the issue! Quote Link to comment Share on other sites More sharing options...
