Results 1 to 2 of 2
    RSS Feed Posting Robot Autodesk's Avatar
    Sep 2006
    746
    Autodesk RSS Feed Changing render background color in AutoCAD® 2007
    You are using AutoCAD 2007 and want to change the render background color. Currently all you can use is the default black.
    More...
    Full Member
    AutoCAD 2009
    Nov 2009
    33
    the link above was broken....so i thought to post the solution here...this solution is still valid to this date for all including aca 2010.
    To change the render background color:
    1. On the View menu, click Named Views.
    2. Click New.
    3. Assign a name and configure the boundary and settings. If you want your background color to appear in modelspace, you must assign a 3D Visual Style.
    4. Select the Override Default Background check box. To change the background color only, set the Type to Solid and click the Color field under Solid Options. Select the color you want.
    5. Click OK three times to return to the View Manager dialog box.
    6. In the View Manager dialog box, select the new named view in the Views tree and click Set Current.
    7. Click OK.
  1. Changing Screen Color
    By Paul Sweet in forum AutoCAD General
    Last Post: 4th Jul 2008, 10:07 am
  2. AutoCAD® commands causing a fatal error
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 5th Sep 2006, 12:18 pm
  3. Before rendering, can I change the background color?
    By Alan123 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Dec 2005, 02:00 am
  4. changing color in color control (layer )
    By ionica in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2005, 07:45 pm
