Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Super Member
    Sengna's Computer Details
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    537
    Quote Originally Posted by Murph_map View Post
    If this is a network version you need to check out (borrow) the license from the License Manager to the laptop, then when you return to the office check it back in.
    http://docs.autodesk.com/CIV3D/2012/...B1462DE-56.htm
    Hmm, i have to give that a try. Just heard about this from you today. Thank you
  2. #12
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    537
    I gave it a shot last night and it works, at least i can open autodesk product (autocad and inventor) when i am away from assign network. Unfortunately, i have to return the license on the due date that i set. I have to do this at when while i have autocad opened and borrow license. Thanks a lot Murph_map
  3. #13
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    Your welcomed, if you are doing this a lot you may want to look at using a option file om the License Manager. You can set it to check in the license automatic after a set time/date. But also be aware borrowing license has cause some issue for some users before.
    Murph
    Need a boat or camper for the weekend?
  4. #14
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    537
    First what is "Option file om the license manager"? how many users can borrow the network license at the same time on the same license?
  5. #15
    Win 7, Win 8
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    924
    The option file is nothing more than a text file you or the server's admin creates. It allows a lot of options on the licenses and use of them. Who logged on and from what workstation etc. It can be set up to return a borrowed license or a user that logged on after a set time. For instance user 1 logs on and then locks his workstation to get a cup of coffee, on the way to the coffee pot or Starbucks the user 1 gets hit by a bus. With out the automatic check in of the license with the options file that instances or license is in used until user 1 comes back to work or your IT hacks his profiles and closes AutoCAD.
    You can only have as many users borrow a license as you have licenses (seats) for.
    http://knowledge.autodesk.com/search...ions-file.html
    Murph
  1. Limited licensing issue? ( Network )
    By orgzchaos in forum Software & Licensing
    Last Post: 19th Mar 2012, 08:45 pm
  2. Replies: 0
    Last Post: 14th Feb 2011, 10:50 pm
  3. AutoCAD MEP 2010 Valid license could not be obtained
    By supragod98 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 15th Oct 2010, 02:34 am
  4. Network license question
    By MikeP in forum AutoCAD General
    Last Post: 11th Mar 2010, 02:25 pm
  5. AutoCAD LT Network License
    By wehaveaproblem in forum Software & Licensing
    Last Post: 20th Sep 2006, 07:00 pm
Tags for this Thread
