wimal Posted September 21, 2014 Share Posted September 21, 2014 (command "line"p1 p2 "") (setq[color="red"] line1[/color] (entlast)) (setq ss1 (car (entsel "\nSelect first cutting line:"))) (setq ss2 (car (entsel "\nSelect second cutting line:"))) (command "trim" ss1 ss2""":N " [color="red"]line1[/color] "" ) Please can somebody correct my code. The line 1 is generated by lisp command. Manually selecting cutting lines I need trim the outer parts of line1 and keep the middle part. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 21, 2014 Share Posted September 21, 2014 The use of the TRIM command in AutoLISP can be very temperamental as it is dependent on the position at which the object is selected, and can also be affected by the current zoom. Since you are only working with lines, it would be far easier & more reliable to calculate the points of intersection using the inters function, and then modify the endpoints of the line you wish to trim. Lee Quote Link to comment Share on other sites More sharing options...
wimal Posted September 21, 2014 Author Share Posted September 21, 2014 OK Thanks, I have never heard about this inters function. Now I can do more. Thanks again. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 21, 2014 Share Posted September 21, 2014 You're most welcome - let me know if you need any help implementing the function. Lee Quote Link to comment Share on other sites More sharing options...
