shaisyuki Posted September 22, 2014 Share Posted September 22, 2014 Hi, I'm new to autocad 2014. I'm involved a lot with sheet metal. Is there any flattend command? For example : I draw a 3d model metal based. Then I use flatten command to flat the model so I know how the model looks in sheet metal before punching and bending process. *theres a flattened command in solidworks. Wondering is there similar thing in autocad 2014 Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 22, 2014 Share Posted September 22, 2014 Welcome to CADTutor. There aren't any sheet metal friendly commands like you are after in Autocad, although Inventor does support such needs, likely virtually identical to Solidworks command options, neither of which I use. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 22, 2014 Share Posted September 22, 2014 Yes, there is a FLATTEN command in AutoCAD. It can be found in your Express Tools. From AutoCAD Help: "FLATTEN creates a 2D representation of selected objects and projects them onto the current viewing plane. FLATTEN results in 2D objects that retain their original layers, linetypes, colors and object types where possible. You can use FLATTEN to create a 2D drawing from a 3D model, or you can use it to force the thickness and elevations of selected objects to 0." Personally I think you would be better off if your were doing your sheet metal work in Inventor not in AutoCAD. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 22, 2014 Share Posted September 22, 2014 ....*theres a flattened command in solidworks. Wondering is there similar thing in autocad 2014 Why are you comparing SolidWorks to AutoCAD? There is not a similar tool in AutoCAD, but you can get an add-in for AutoCAD. If you are doing software comparisons - Autodesk Inventor is the equivalent product to SolidWorks and has sheet metal tools. Quote Link to comment Share on other sites More sharing options...
nukecad Posted September 22, 2014 Share Posted September 22, 2014 Yes, there is a FLATTEN command in AutoCAD. It can be found in your Express Tools. Be careful here, Autocads Flatten command just shows a projection of the geometry on a 2D plane, ie it puts everything on Z=0. What the Solidworks command does would be better described as "DEVELOP" or maybe "UNBEND" where it calculates what shape you need to cut from a flat sheet to enable it to be folded into the finished shape. Quote Link to comment Share on other sites More sharing options...
shaisyuki Posted September 23, 2014 Author Share Posted September 23, 2014 Because I have yet to get Inventor, and I'm so used to autocad. Thanks for sharing guys. Quote Link to comment Share on other sites More sharing options...
scj Posted September 23, 2014 Share Posted September 23, 2014 See http://www.ant-ares.de Regards Jochen Quote Link to comment Share on other sites More sharing options...
shaisyuki Posted September 23, 2014 Author Share Posted September 23, 2014 See http://www.ant-ares.de Regards Jochen Hi thanks, for the help. I've downloaded PEDIT3D_V6,4_ENG.VLX. But how do I install this to my autocad? I've noticed its for unroll. Does it have unbend function as well? Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 23, 2014 Share Posted September 23, 2014 To load the program use the APPLOAD command just as you would for a lisp routine. Under File of Type there is an option for Visual LISP Executables (.vlx). I'm assuming Pedit3D would be the command to run it but I'm not 100% sure. Quote Link to comment Share on other sites More sharing options...
