Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 56
    Junior Member
    AutoCAD 2012
    Mar 2014
    15
    Default Dimscalelinear is Squaring itself?
    I am not sure if this is the correct subforum to post this in, so move it if I am incorrect.
    So I have a drawing, and I was experiencing the following problem. My layout scale is set to 1:75. I would place my dimensions in paperspace, and they came out correct. However, next, when I move the dimensions within paperspace, the dimscalelinear value squares itself (in this case, it turns into 5625, or 75 squared).
    Does anyone know what is causing this to happen. As best I can tell it does not happen to every dimension, just some.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,955
    Can you post a drawing showing this behavior?
    Junior Member
    AutoCAD 2012
    Mar 2014
    15
    The actual file? I'm not sure that I can as it has information about my plant in it.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by ilarson007 View Post
    What is dimscalelinear? I seem to not have one.
    When you move paperspace dimensions, they sometimes become disassociated from the modelspace objects and give you the paperspace dimension. The squaring is probably just a math coincidence.
    1:75? That is an uncommon scale, not that it has anything to do with this issue.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Junior Member
    AutoCAD 2012
    Mar 2014
    15
    Quote Originally Posted by Dana W View Post
    Yeah, that is just the scale that fit my drawing into my layout correctly.
    Let me clarify what I meant by moving my dimension. I just mean that I am moving the location of the numbers in the dimension, not the points that the dimension is "reading" from. Also, I snap to the same point for a lot of my dimensions, but I am not convinced all the time that the dimension snaps to the say corner of a rectangle, or if it is snapping to the node of another dimension that has snapped to the same corner.
  6. #6
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Using non-standard scales, just because it fits your layout, can lead to trouble.
    Use OSNAP overrides to ensure you are snapping to the proper point.
    Drafting is a breeze.
  7. #7
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Yeah, those two things can cause the disassociation. I usually turn nodes off, unless I really, really need one. And I use annotative modelspace dimensions. Paperspace dimensions are rife with quicksand.
  8. #8
    Junior Member
    AutoCAD 2012
    Mar 2014
    15
    In the properties window.
  9. #9
    Junior Member
    AutoCAD 2012
    Mar 2014
    15
    I always found it easiest to dimension in paper space, because you can have different layout scales and not have to worry about trying to get a dimension size that works in multiple scales.
  10. #10
    Junior Member
    AutoCAD 2012
    Mar 2014
    15
    Quote Originally Posted by RobDraw View Post
    Yeah, the only other options were 1:50 and 1:100. Neither worked....
    I know how to do that, but I guess I just didn't?
  1. Vba Macro : automatic create Squaring and cartouche (Sheet)
    By zadboda in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Dec 2008, 03:03 pm
