Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 56
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    "Paperspace dimensions are rife with quicksand."
    Only if the user doesn't know what he is doing in the first place or 1) he fails to use OSnaps during dimensioning, 2) fails to enable the "associative" property of dimensions, 3) is attempting to dimension a 3D model that is displayed in Conceptual or Realistic visual style thus leaving himself open to the possibility that AutoCAD will pick the wrong geometry. We do all our dimensioning and text in our layouts not in model space and have had no problems since adopting this method several years ago.
  2. #12
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Quote Originally Posted by ilarson007 View Post
    In the properties window.
    Is DIMASSOC set to a value of 2?
  3. #13
    Junior Member
    AutoCAD 2012
    Mar 2014
    15
    It is set to 1
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    A setting of 1 create non-associative dimensions while a setting of 2 creates associative dimensions. That might explain the problem.
  5. #15
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    You just did a pretty good job of describing the quicksand to a "T".
    I don't have a huge amount of problems with paperspace dimensions, but occasionally I will see some unexplained loss of associations when I move or stretch a modelspace object.
    More often than not, if a paperspace (or otherwise) dimension fails to stay associated to the modelspace objects, it's because I was a little hasty in setting the node down and missed the osnap point by a thou or so, but I have not found yet a node floating in space when the above happens. I have gone as far as checking the .bak file to see what it looked like before the editing.
    I only do paperspace dimensions for one single client. Everyone else is satisfied with annotative modelspace dimensions.
    Also, every angular dimension that needs the text moved out of a tight spot suddenly decides to measure paperspace once the text starts moving. The nodes do not move, just the text, and then it can't be fixed without replacing it.
    All of that sounds like loss of associativity, but how and why, I cannot determine.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    If I encountered a user with that problem, on a consistent basis, I'd say it was a case of OIE. Someone is not paying attention to what they are doing.
  7. #17
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Yeah, the only other options were 1:50 and 1:100. Neither worked....
    Unless I am mistaken, 1:75 is not found on standard metric architectural scales. What if someone wants to verify a dimension that is not noted? Are you going to provide a hard to find scale with your drawings so that they can take a measurement?
    Drafting is a breeze.
  8. #18
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    Quote Originally Posted by RobDraw View Post
    Neither is it on a standard Engineering Imperial scale.
  9. #19
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by Dana W View Post
    Why would it be? Engineering scales are inches = feet not a ratio ( : ) like metric scales.
  10. #20
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    Yeah. me too but as far as I can tell I exhausted that possibility. It is not all that regular that I see the stuff described. Most recently, it occurred in a drawing that I did for Universal at Diagon Alley so I may just write it off as having to deal with wizards, goblins, and muggles. The contractor I did that work for is the only one I have to do paperspace dimensions for anyway.
    At first, I thought I was simply stacking dimension nodes on each other instead of the object snap, so I turned node snap off and re-did them. Then, I increased the size of all my snappy tool symbols so my ancient eyes could see better which one I was actually snapping to, and found no surprises there either. >>> shrug <<<
    Maybe AutoCad knows I prefer not to use paperspace dims and is just having an ego fit.
  1. Vba Macro : automatic create Squaring and cartouche (Sheet)
    By zadboda in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Dec 2008, 03:03 pm
