svrkjg Posted September 22, 2014 Share Posted September 22, 2014 Hello All, Thank you in advance. I can't seem to fix the error I keep getting no matter ho many times I do a "Attempt to Heal all Faces" procedure. I must be missing something here I can't see. Any advice or website link will be helpful. File is attached Ken Solidworks 2014 Standard Faulty Face Issue.zip Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 22, 2014 Share Posted September 22, 2014 Worked fine for me on first run of Attempt to Heal All. Quote Link to comment Share on other sites More sharing options...
svrkjg Posted September 22, 2014 Author Share Posted September 22, 2014 Hello JD, Thanks for your quick reply. I also was able to heal the face but when I opened up again I got the same error? Ken Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 23, 2014 Share Posted September 23, 2014 I tried again, this time I saved and closed the file. When I re-opened and ran Import Diagnostics a second time - it was OK. Not sure what is happening on your machine. Quote Link to comment Share on other sites More sharing options...
svrkjg Posted September 23, 2014 Author Share Posted September 23, 2014 Hi JD, Thanks again for your great support. There must be something wrong in my settings, when I created the Step file or during import/export operations. I'll have to see if tech support can help me, I might have a software glitch. Best Regards KenJG Quote Link to comment Share on other sites More sharing options...
