Text issues
FIFTHTEXAS
I have noticed from time to time that text on drawings does not look the same
even if the setting on each text is same ie. Arial 2.5 on same layer, i find some text looks thicker than other
and you can notice on drawings, i have been trying to get text exactly same thickness, does anyone one know why this happens?
On screen text looks ok, it when you print out, i am using same symbol and legend, symbol is ok, its just the text that is the problem, its slightly thicker slightly different, everything on same layer, its like a glitch, sometimes its ok, other times i keep getting this fault, its not printer as i have worked in few companies now, and i find the same sort of thing happening, its not a big problem but just baffled why this happens.
