Fix MTEXT format from Revit
nod684
everytime i export Revit File to AutoCAD, all text become MTEXT.
whats worse is that even the numbered / letter bullet becomes an MTEXT as a single MTEXT entity as the paragraph also as a single entity.
I do export revit file to autocad frequently, and hopes that there is a better way to fix this
can i ask for a way to turn this back on to its proper format?
please see attached file for a clearer explanation
temp2.dwg
Edited by nod684
Maybe this program by ronjonp can help?
http://www.theswamp.org/index.php?topic=35607.0
thanks a lot Lee! ill go check this one out.
EDIT :
thanks for the link Lee!
it worked.
i just changed this part to suite my need.
(if (and (setq ss (ssget ":L" (list '(0 . [color=royalblue]"text[/color]"))))
to
(if (and (setq ss (ssget ":L" (list '(0 . [color=royalblue]"*text[/color]"))))
thanks to ronjonp as well
cheers!
Edited by nod684
