Damon :) Posted September 29, 2014 Share Posted September 29, 2014 How do you create multiple Paper Space layouts? Quote Link to comment Share on other sites More sharing options...
mikekmx Posted September 29, 2014 Share Posted September 29, 2014 you can right click a tab and chose to copy you can use Design Centre to 'import' an existing one from elsewhere. Quote Link to comment Share on other sites More sharing options...
Damon :) Posted September 29, 2014 Author Share Posted September 29, 2014 That helps a lot, thanks. Also, how can Model Space be used to layout a drawing ready for printing/plotting? You can tell I'm a beginner Quote Link to comment Share on other sites More sharing options...
mikekmx Posted September 29, 2014 Share Posted September 29, 2014 That helps a lot, thanks.Also, how can Model Space be used to layout a drawing ready for printing/plotting? You can tell I'm a beginner hth Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 30, 2014 Share Posted September 30, 2014 You can plot from either principles are the same a sheet of paper at scale. I would recommend using layouts though there are lots of tutorials search here. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 30, 2014 Share Posted September 30, 2014 When plotting from a layout you will typically be plotting 1:1. AutoCAD will automatically scale the viewports. When plotting from model space you may not always be plotting 1:1. Plotting 3D models, in my opinion, is easier if done from a layout. Quote Link to comment Share on other sites More sharing options...
