hamidciv Posted September 30, 2014 Share Posted September 30, 2014 hi dear friends :(i define one door As the block, I've used it in several parts of the plan , now i want when change in block refrence, All blocks have changed, how do this? Some of the doors have been scaled. please help me. thanks Quote Link to comment Share on other sites More sharing options...
hamidciv Posted September 30, 2014 Author Share Posted September 30, 2014 one way is edit block in-place, otherwise there is one way , please tell me? thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 1, 2014 Share Posted October 1, 2014 Have to go to work now but here is a start it can be done very simply (vl-load-com) (setq obj (vlax-ename->vla-object (car (entsel)))) (vla-put-name obj "Your new block name") ; need to add scale etc will try to find time Quote Link to comment Share on other sites More sharing options...
dbroada Posted October 1, 2014 Share Posted October 1, 2014 are you asking to change all the blocks in the same way? Is so you can BEDIT or REFEDIT and all blocks will change the same - this is how blocks work. You can also reinsert & redefine from another drawing using the design center or from an external file. If you only want one of the blocks to change you will have to create a new different block or create a dynamic block. Quote Link to comment Share on other sites More sharing options...
hamidciv Posted October 1, 2014 Author Share Posted October 1, 2014 dear dbroada using bedit or refedit after create block , if we use insert for define other object ,In this case, if we use these two commands to change the resource blocks of other object do not change and only refrence block edited, In other words this two commands To change all blocks in same time we should used copy command for generate other objects. if your possible more explain about reinsert and redefine?(are this two methods also canged objects in same time? whether yor mean of redefine : i again create block with same name?) also reinsert explain for me. thanks a lottttttttt Quote Link to comment Share on other sites More sharing options...
dbroada Posted October 1, 2014 Share Posted October 1, 2014 no. If you have 10 blocks, all identical and you change one of them using BEDIT or REFEDIT, all 10 will change. Also, any future inserting of that named block will insert the most recent definition. If that is not happening there is something wrong with your block or AutoCAD installation. You can use the design center to grab a block from another drawing. If that block is already in your current drawing you can redefine all the blocks in your current drawing to match the one in the drawing specified in design center. Give it a try. Its easier to use than explain. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 1, 2014 Share Posted October 1, 2014 You must be doing something wrong. If you have five copies of a single block in a drawing and use BEDIT to make additions or deletions to the block when you save and close BEDIT all five blocks will display the changes. As regards "ReDefine". Same example as before. Five copies of a single block. Explode one copy and edit it. Start the Block command. Use the same block name. Pick the same insertion point. Select all the objects. When done click on the OK button. When you do a message will appear that looks like this.... Select the option that is circled in red. When you return to your drawing all five blocks will now be updated to reflect the changes that were made. Now do you understand? Note: Both methods tested using AutoCAD 2013. Quote Link to comment Share on other sites More sharing options...
hamidciv Posted October 1, 2014 Author Share Posted October 1, 2014 (edited) dear remark :(i already know redefine block with same name for all changes in drawing but I am faced with the error.(i after modify block refrence , make a block with same name and select block reference but get error. Edited October 1, 2014 by hamidciv hamidciv Quote Link to comment Share on other sites More sharing options...
dbroada Posted October 1, 2014 Share Posted October 1, 2014 now we see the error. You are NOT creating your block correctly. You are not exploding your block before creating it again with the same name. Quote Link to comment Share on other sites More sharing options...
hamidciv Posted October 1, 2014 Author Share Posted October 1, 2014 oops, Your order exactly was correct. very thanks dear dbroada:) Quote Link to comment Share on other sites More sharing options...
