rupert Posted October 1, 2014 Share Posted October 1, 2014 At my office, we are using AutoCAD 2008LT. Yesterday, my coworker noticed an issue where she discovered that she can open the same .dwg file multiple times, without the 2nd and so-on opening as read-only. Obviously, this is not a good situation, as it means that more than one coworker can potentially be working on the same file. Any ideas? Thanks. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 1, 2014 Share Posted October 1, 2014 I think either AutoCAD was not reporting them as read only or she was mistaken. Have you actually tested this "theory" to see if it is indeed what is happening? Quote Link to comment Share on other sites More sharing options...
rupert Posted October 1, 2014 Author Share Posted October 1, 2014 I did test it as far as watching her open the same .dwg file 3 times, without it showing them as read-only. So it could be like you said, and AutoCAD was just not showing them that way? We didn't try to save the 2nd+ opened versions to see what would happen though. It seems to be moot at this point though. Literally seconds after I posted, she told me that her computer is back to normal. She hasn't changed any setting or rebooted her computer or Autocad since yesterday. So I don't really know why it's working again. [shrugs] lol Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 1, 2014 Share Posted October 1, 2014 Yeah, one instance does not indicate a problem. You need to check other possibilities before making assumptions. Quote Link to comment Share on other sites More sharing options...
