Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Super Member
    AutoCAD LT 2014
    Sep 2008
    545
    Default Line Type Will Not Change
    Have a drawing where the line type stays a center line instead of the layer line type of continuous. Trying to change but it doesn't. Continuous is loaded, the line type for the layer I'm working on is continuous, but line comes out center line type.
    CADTUTOR.dwg
    OK, I think I solved the problem. The properties mgr. was set to Linetype: Center.
    I changed to continuous and it works fine now. I haven't used the prop mgr. much, but this is a new one for me. I thought the layer mgr. linetype dictated the linetype type for that layer.
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, W8 + W8.1 Vista
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    Open your drawing that you posted and without selecting anything go to the properties panel (if it's not open press Ctrl+1) and under General set Linetype to "ByLayer". that should solve your problem.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
    Super Member
    AutoCAD LT 2014
    Sep 2008
    545
    Quote Originally Posted by Tyke View Post
    OK, that's what I needed. It's in the bible now. Thank you Tyke and have a great day.
    Glenn
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,727
    Quote Originally Posted by gsksun4 View Post
    Attachment 51107
    The layer property only dictates the property value IF the object property is set to By Layer. Therefore, it is the individual object property that takes precedence. However, the object property will default to By layer if you create a new object, a line for instance, without mucking about with the properties.
    On the Home ribbon tab, there is a properties tile, you will see a set of properties drop down selection lists available. These are not the layer properties, but the object properties. When you create a new object, make sure the above are set to By layer if you want the current layer to set the property values. If you change one of them, it will not change back to By Layer for the next object by itself.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Super Member
    AutoCAD LT 2014
    Sep 2008
    545
    Quote Originally Posted by Dana W View Post
    I don't use the ribbons, I use classic, but that makes sense when you spell it out like that. It's the same principal as the props mgr. setting in General to Bylayer.
    Thanks very much, you folks are the best.
  6. #6
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,727
    Use the Ribbon, Luke. You must learn the ways of the Ribbon, if you're to come with me to Alderaan.
  7. #7
    HP Z400 Workstation
    8 GB
    Multi-disciplinary
    Multi-disciplinary
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    What Dana said is perfectly correct. My answer was just to solve your problem. Take note of everything that you learn fro here, it will only benefit you.
    Thanks Dana for expanding on that.
  8. #8
    Super Member
    AutoCAD LT 2014
    Sep 2008
    545
    I always note things I learn here and it's nice we have this forum to rely on.
    Thanks again to both of you and have a great day.
    Glenn
  9. #9
    AutoCAD 2013
    Nov 2011
    5,986
    Dana, I trust you haven't told Daisy that you have gone over to the dark side.
  10. #10
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,727
    Quote Originally Posted by Dadgad View Post
    Um, Dark Side? Is that why she acts like I'm her Father?
  1. Draw a line with color line type and layer
    By satishrajdev in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Oct 2012, 08:27 am
  2. line type doesn't update after change is made to the xref file
    By salmonrose in forum AutoCAD Beginners' Area
    Last Post: 18th May 2012, 03:45 pm
  3. Break the line and change the line type
    By nalsur8 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2011, 02:12 pm
  4. Line type scales change.... BIG PROBLEM
    By RICO in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 25th May 2011, 07:28 am
  5. Can't change line type, need some help guys.
    By T.A. Metal in forum AutoCAD Beginners' Area
    Last Post: 3rd Nov 2008, 05:08 pm
