madriver Posted October 2, 2014 Share Posted October 2, 2014 So I’ve done this many times, edited an existing .pat file in a text editor and then saved it as…(new file name) but for some reason it is not saving is as a .pat file…..? Missing something simple here….thanks for any help. Quote Link to comment Share on other sites More sharing options...
Dana W Posted October 2, 2014 Share Posted October 2, 2014 The text editor, Notepad probably, has no idea what a .pat file is. Are you typing out the FULL file name, including the .pat extension? If so, and it is still not working, you can simply do a Windows rename on it after saving. Windows of course will kvetch about the extension change with a warning message. Quote Link to comment Share on other sites More sharing options...
madriver Posted October 2, 2014 Author Share Posted October 2, 2014 Thanks what it seems to be is that by doing a "save-as" from a previously edited "save-as" file it would not save as a ".pat" file. I couldn't even rename it as a .pat file. I had to go back to an original .pat file and then I could save it as a .pat file. All good and thanks again. Bob Quote Link to comment Share on other sites More sharing options...
