Guest Posted October 6, 2014 Share Posted October 6, 2014 Hi , I am trying to write a lisp to draw a polyline in specific layer with Global width 0.10 here is the code (defun C:PLGB (/ plw) (COMMAND "_layer" "_m" "Global PL" "_c" "25" "DASHED2" "_lt" "DASHED2" "DASHED2" "") (COMMAND "_linetype" "_s" "DASHED2" "") (setq plw (getvar 'plinewid) (setvar 'plinewid 0.10) (command "_.pline") (setvar 'plinewid plw) ) ); defun This code gives me this message ; error: syntax error Can any one help me ? Thanks Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted October 6, 2014 Share Posted October 6, 2014 (defun C:PLGB (/ plw) (COMMAND "_layer" "_m" "Global PL" "_c" "25" "DASHED2" "_lt" "DASHED2" "DASHED2" "") (COMMAND "_linetype" "_s" "DASHED2" "") (setq plw (getvar 'plinewid)[color="red"][b]) [/b]; missing parentheless?[/color] (setvar 'plinewid 0.10) (command "_.pline") (setvar 'plinewid plw) [color="red"] <--- remove this[/color] ); defun Quote Link to comment Share on other sites More sharing options...
Guest Posted October 6, 2014 Share Posted October 6, 2014 thank you for the reply hanhphuc I do the changes but i can not see the global width 0.50 . It still 0 ? (defun C:PLGB (/ plw) (COMMAND "_layer" "_m" "Global PL" "_c" "25" "DASHED2" "_lt" "DASHED2" "DASHED2" "") (COMMAND "_linetype" "_s" "DASHED2" "") (setq plw (getvar 'plinewid)) (setvar 'plinewid 0.50) (command "_.pline") (setvar 'plinewid plw) ); defun I want to add global width 0.50 line type scale 0.10 The collor of the layer is white and not 25 (i don't now why ? ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 6, 2014 Share Posted October 6, 2014 Try the following: (defun c:plgb ( / lay val var ) (setq var '(clayer plinewid cmdecho celtscale cecolor celtype) val (mapcar 'getvar var) lay "Global PL" ) (mapcar 'setvar (cdr var) '(0.5 0 0.1 "bylayer" "bylayer")) (command "_.-layer" "_m" lay "_c" 25 lay "_l" "dashed2" lay "_t" lay "_u" lay "_on" lay "_s" lay "") (setvar 'cmdecho 1) (command "_.pline") (while (= 1 (logand 1 (getvar 'cmdactive))) (vl-cmdf "\\")) (mapcar 'setvar var val) (princ) ) Quote Link to comment Share on other sites More sharing options...
Guest Posted October 6, 2014 Share Posted October 6, 2014 Hi Lee Mac . I try your code but the results is not exactly what i want. I want to create a layer with name "Global PL" and color 25 with line type "dashed2" but a) in the line type Manager I want global scale factor 1 ,current object scale 1 b)When i select the polyline --> have global width 0.50 Look the attach photo Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted October 7, 2014 Share Posted October 7, 2014 I try to understand something in 1.dwg file lisp works perfect. in 2.dwg file the polyline have the same settings with 1.dwg but is not the same !!!! I can not understand (defun c:plgb ( / lay val var ) (setq var '(clayer plinewid cmdecho celtscale cecolor celtype) val (mapcar 'getvar var) lay "Global PL" ) (mapcar 'setvar (cdr var) '(0.5 0 0.1 "bylayer" "bylayer")) (command "_.-layer" "_m" lay "_c" 25 lay "_l" "DASHED2" lay "_t" lay "_u" lay "_on" lay "_s" lay "") (setvar 'cmdecho 1) (command "_.pline") (while (= 1 (logand 1 (getvar 'cmdactive))) (vl-cmdf "\\")) (mapcar 'setvar var val) (princ) (setvar 'CELTYPE old_clt) [color="red"]; I add this line to the code and now global scale factor 1 ,current object scale 1[/color] ) Thanks 1.dwg 2.dwg Quote Link to comment Share on other sites More sharing options...
