Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Maybe you thought magic could be used?
    Since AutoCAD does not have a built in command that will do the job in one click then the only other alternative is a custom lisp routine. Until then you're faced with doing it manually.
  2. #12
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    A good template will get most of the job done.
    Set it up so that you don't have to use the backwards option in the style.
    Once that is done, you open the file, type the information, explode, extrude, and export.
    The last three steps could probably be coded but how much time would that really save? Would it affect how much work you get done in a day?
    Drafting is a breeze.
  3. #13
    Forum Newbie
    AutoCAD 2014
    Oct 2014
    7
    Indeed, i was thinking about using some kind of a macro. I m going to try that. I keep you guys posted. Tanx for the input!
    Just extruding and exporting / saving in .stl doesn't take time and isn't worth the pain of involving lisp probably.
    Grtz
  4. #14
    Forum Newbie
    AutoCAD 2014
    Oct 2014
    7
    Robdraw, can you be a little more specific on setting up the template without involving any backwards style? Like a template that mirrors everything by default?
  5. #15
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Make sure MIRRTEXT is set to 1 and mirror the text. While you edit the text, it will appear normal.
  1. Macro textstyle
    By DDTarrant in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jul 2013, 04:27 pm
  2. Textstyle and Dimstyle
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2010, 02:13 pm
  3. Font Import
    By conortist in forum AutoCAD Beginners' Area
    Last Post: 17th Feb 2009, 06:35 pm
  4. Crazy Textstyle
    By bamaman83 in forum AutoCAD General
    Last Post: 23rd Sep 2008, 01:43 pm
  5. Leader Mtext Textstyle..
    By hardwired in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Mar 2008, 03:30 pm
Tags for this Thread
