Akitirija Posted October 7, 2014 Share Posted October 7, 2014 Hi Just a quick question concerning cut extrude on circular surfaces: Is the cut extrude I have done in the attached file a "best practice" way of doing it (the sketch is way past the circumference of the circle, so I am trying to ask if this matters, or if there is some "prettier" way of doing the sketch). Stepped shaft.SLDPRT Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 8, 2014 Share Posted October 8, 2014 (edited) You do not need the 4mm dimensions - simply add Tangent relations between the sides and the circle. (Or in this case you could also use Coincident since you already have a construction line constrained to the circle.) I would have used a center point rectangle instead. Edited October 8, 2014 by JD Mather Quote Link to comment Share on other sites More sharing options...
Akitirija Posted October 8, 2014 Author Share Posted October 8, 2014 Thank you very much, I will try this! Quote Link to comment Share on other sites More sharing options...
