basty Posted October 9, 2014 Share Posted October 9, 2014 What is the dimension of h shown in the image? Any standard of it? Thank you Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 9, 2014 Share Posted October 9, 2014 (edited) Well if you are referencing the British Whitworth thread then h = 0.640327 p where "p" is the Pitch. There are charts for this type of information. http://www.metrication.com/engineering/threads.html Pitch: The pitch of a thread is the distance, parallel to the axis, from a point on one thread to the corresponding point on the next adjoining thread. Source: Basic Technical Drawing by H.C. Spencer. If you referencing Metric ISO 724 general purpose metric screw threads then use 0.614 p for the depth. Edited October 9, 2014 by ReMark Quote Link to comment Share on other sites More sharing options...
nestly Posted October 9, 2014 Share Posted October 9, 2014 That doesn't really look like a "standard" bolt size. What size bolt is it supposed to be? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 9, 2014 Share Posted October 9, 2014 Did you draw that or did someone else draw that image? (It is drawn incorrectly.) Quote Link to comment Share on other sites More sharing options...
mikekmx Posted October 21, 2014 Share Posted October 21, 2014 Did you draw that or did someone else draw that image? (It is drawn incorrectly.) what is it? Quote Link to comment Share on other sites More sharing options...
basty Posted October 27, 2014 Author Share Posted October 27, 2014 This is the standard of the bolt. It doesn't include the thread detail. The thread has its own standard. Quote Link to comment Share on other sites More sharing options...
smithdoor Posted October 27, 2014 Share Posted October 27, 2014 Today I use http://www.mcmaster.com/#screws/=uc28vp They have dwg files of nuts and bolts in 2D and 3D Dave Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 27, 2014 Share Posted October 27, 2014 basty: Looks like you forgot to read page 1 of the PDF you got that image from.... Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 28, 2014 Share Posted October 28, 2014 ....It doesn't include the thread detail.... The information is readily available in the Machinery's Handbook and on (thousands of?) websites. This information is usually covered in basic classroom instruction. This tutorial is for a different size - but the dimensions are proportional. Once you can do one size - you should be able to do any size http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%204.pdf in fact, if you set up with a Parametric table (in later versions of AutoCAD) AutoCAD can create the various sizes for you. Quote Link to comment Share on other sites More sharing options...
