mrjagsr744 Posted October 10, 2014 Share Posted October 10, 2014 I created a command in the CUI (2014) with a macro that has the following ucsicon;or;ucs;3;_dimlinear; and I don't understand why when I run the command, it never runs the "dimlinear" portion of the command. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 10, 2014 Share Posted October 10, 2014 UCSICON OR expects a pt try UCSICON;or;pause;UCS or UCSICON;OR;('(0 0 0));UCS Quote Link to comment Share on other sites More sharing options...
mrjagsr744 Posted October 11, 2014 Author Share Posted October 11, 2014 Thanks for your answer but the Macro works fine all the way up to the completion of the "UCS 3 point" and then it stops. What is preventing it from continuing to the "Dimlinear" command? I tried the Macro one line at a time and every single line works, except when they are together. Any other ideas? Quote Link to comment Share on other sites More sharing options...
YZ Posted October 13, 2014 Share Posted October 13, 2014 I don't understand the part UCS;3 When I try that part, it seems AutoCAD is then asking for a new origin point. What does your command line say when you run this macro? Quote Link to comment Share on other sites More sharing options...
mrjagsr744 Posted October 13, 2014 Author Share Posted October 13, 2014 What was happening was that the macro would do the following: 1. it would set the ucsicon to ON 2. it would set the UCS using 3 points 3. at this point it would stop without continuing to the dimlinear command. I posted this problem in the Autodesk forums and I got an answer, the macro should say ^C^C_.ucsicon _or _.ucs _3 \\\_.dimlinear We do a lot of dimensioning 3D piping fabrications and wanted to simplify the process of locating the UCS on the right plane for the dimension to appear and this macro now works. Quote Link to comment Share on other sites More sharing options...
