tzframpton Posted October 13, 2014 Share Posted October 13, 2014 It is, but work dictates use of another SoftWare. I am probably faster in the other SoftWare right now just because I use it so much in the classroom.Use of the Marking Menus/Mouse Gestures develop "muscle memory" that want me to go without thinking.... ...and I end up in the wrong place. With true pros dedicated to one system - you would never even see the tools on the screen as all would be gesture based. So which do you prefer... SolidWorks or Inventor... "if" you had to choose? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 13, 2014 Share Posted October 13, 2014 So which do you prefer... SolidWorks or Inventor... "if" you had to choose? Uhmm, I thought I stated my preference in that response (taken in context). Quote Link to comment Share on other sites More sharing options...
tzframpton Posted October 13, 2014 Share Posted October 13, 2014 After your wise-crack response I re-read it... and now I see which one you prefer. Any particular reason? Or just because you're used to Inventor more, or your first love... etc? Quote Link to comment Share on other sites More sharing options...
nathanjh13 Posted October 21, 2014 Author Share Posted October 21, 2014 This is great folks and it seems that everybody has given the challenge a go! If you have any links of yourself completing the challege (I have watched the ones posted here and they are great) please post them in the Comments section on the original Youtube clip as it would be great to have a central "Respository" of shared learning for this task)! If you don't have a Youtube/gmail login then with your permisson I will post the link for you. Well done folks! Best Quote Link to comment Share on other sites More sharing options...
Organic Posted October 26, 2014 Share Posted October 26, 2014 I started with a three sided polygon. This is how I done it; simplify it down to basics. Not a bad one to add to my CAD test. Quote Link to comment Share on other sites More sharing options...
Strix Posted November 1, 2014 Share Posted November 1, 2014 One student I teach used a 3 point circle to get the centrepoint of the shape and constructed the 45mm circle from there. That method is smart but I can't use it as I need my Centre object snap turned off by then (or it overrides Tangent). In fact changing object snap is the most time consuming part I've found and I only do it once. Is it no longer possible to cycle through the OSnaps? Doesn't the tab key do it? Quote Link to comment Share on other sites More sharing options...
Organic Posted November 1, 2014 Share Posted November 1, 2014 Is it no longer possible to cycle through the OSnaps? Doesn't the tab key do it? Right click menu when you have a selection set active brings up snap overrides I think from the top of my head. I can't recall ever cycling through osnaps. Quote Link to comment Share on other sites More sharing options...
Dana W Posted November 1, 2014 Share Posted November 1, 2014 Is it no longer possible to cycle through the OSnaps? Doesn't the tab key do it?Yes, Tab still cycles through the snaps. Welcome back. Quote Link to comment Share on other sites More sharing options...
Strix Posted November 4, 2014 Share Posted November 4, 2014 Thanks Dana Quote Link to comment Share on other sites More sharing options...
Strix Posted November 4, 2014 Share Posted November 4, 2014 Right click menu when you have a selection set active brings up snap overrides I think from the top of my head. I can't recall ever cycling through osnaps. Try tabbing instead of switching on and off. It's much less faffing, and much quicker once you know the tab cycle and don't have to watch which ones are coming up Quote Link to comment Share on other sites More sharing options...
