Polar Array in Autocad 2014
Now the step to do the polar array is different from the old one, what is the step to make a polar array like below image in AutoCAD 2014 in classic workspace?
Use the command ARRAYCLASSIC. It will work like older versions of autocad
Nice info, thank you. But what is the step if I want to use polar array in classic workspace without using arrayclassic?
The workspace you are currently using has no bearing on the functionality of the command. Use ARRAYCLASSIC as previously suggested.
From the menu bar: Modify > Array > Polar then look at the command line. Or...ArrayClassic. Or....Array Toolbar and edit the CUIx changing POLARARRAY to ARRAYCLASSIC.
Edited by ReMark
You will want to watch the command line since you don't want to use the Ribbon. At the command line to get the number of Items you want you will type I and then 4.
