kirasmith Posted October 12, 2014 Share Posted October 12, 2014 Hi, i'm new here - kinda weird talking to a space.... I've recently upgraded from 2009 to 2013 and all the settings are on default... (plus i'm swithing from Classic to Ribbon layout... whoohooo .when i'm drawing in 3D,- solids and lines, i cannot draw or dimension those objects in the front elevation, it seems to read my lines or dimensions only in one plane -namely top view. Not sure if this is a UCS issue or not? PleAse help me to fix it ! Thanks Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 12, 2014 Share Posted October 12, 2014 You posted in the 3D Studio Max section. I have moved your question to the Autocad 3D section. Since you are new here, you should take a few minutes to browse the site and get acquainted with the various sections of the forum. Posting in the correct area will insure your question gets viewed by the right people and answered as quickly as possible. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 12, 2014 Share Posted October 12, 2014 Did 2009 have DUCS? Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 13, 2014 Share Posted October 13, 2014 The Dynamic UCS (DUCS) feature was first introduced in AutoCAD 2007. "Use dynamic UCS to speed up 3D drawing" by Ellen Finkelstein. http://www.ellenfinkelstein.com/acadblog/use-dynamic-ucs-to-speed-up-3d-drawing/ Quote Link to comment Share on other sites More sharing options...
nestly Posted October 13, 2014 Share Posted October 13, 2014 Hi, Not sure if this is a UCS issue or not? It is. I suspect you're using the Viewcube to change to front view, but that only changes the view, it does not change the drawing plane. Instead, use the In canvas view controls in the upper left to switch to "Front" and/or the Ribbon. Quote Link to comment Share on other sites More sharing options...
kirasmith Posted October 15, 2014 Author Share Posted October 15, 2014 It works!! yes!! THANK YOU so happy i don't have to use the cube for drawing anymore i did find it a bit frustrating! but i suppose i'll get used to it, along with the ribbon. This is fantastic! Quote Link to comment Share on other sites More sharing options...
