muck Posted October 13, 2014 Share Posted October 13, 2014 I have been debugging my vb.net program with AutoCAD 2014. Now I have moved to a computer with 2013 and vb.net express and my program is not set to use AutoCAD 2013. Is there a way to change my program to allow me to use AutoCAD 2013 for debugging? Thank you, Quote Link to comment Share on other sites More sharing options...
Tyke Posted October 14, 2014 Share Posted October 14, 2014 How are getting the active document? If you are using late binding you just need to change the version number. In the VB.NET Express in the project properties point to AutoCAD 2013 and rebuild your program. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted October 15, 2014 Share Posted October 15, 2014 In your Solution's Project folder, edit the *proj.user file (XML content) with a text editor of your choice, and modify the file path value of the StartProgram XmlNode. Cheers Quote Link to comment Share on other sites More sharing options...
