Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2013
    Oct 2014
    2
    Default Autocad Script to plot multiple tabs in one file
    HI, I HAVE A SIMPLE SCRIPT FILE THAT PRINTS SPECIFIC TABS INSIDE A CAD FILE, IS IT POSSIBLE TO CHANGE THIS TO MAKE IT PLOT MULTIPLE TABS "LAYOUTS" IN THE SAME FILE, BASICALLY WILL BECOME EQUIVALENT TO A PUBLISH "BATCH PLOT" COMMAND.
    -PLOT
    Y
    PV2.00
    DWG TO PDF.PC3
    ARCH full bleed E1 (30.00 x 42.00 Inches)
    I
    L
    N
    L
    F
    Y
    SoCore_2014.ctb
    Y
    Y
    Y
    N
    N
    Y
    Y
    THNX
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by YAZ View Post
    The obvious answer would be to use publish and named page set-ups. (Or is it sets-up?)
    Drafting is a breeze.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,170
    Here is a quick answer, we have 2 versions plot all or this one plot range.
    Code:
    ;Plots layouts by range
    ; By Alan H Feb 2014
    (defun AH:pltlays ( / lay numlay numend)
    (setq numlay (getint "\nEnter Start tab number"))
    (setq numend (getint "\nEnter last tab number"))
    (setq len (+ (- numend numlay) 1))
    (repeat len
    (vlax-for lay (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))
    (if (= numlay (vla-get-taborder lay))
      (setvar "ctab" (vla-get-name lay))
    ) ; if
    (princ (getvar "ctab"))
    ) ; for
    (setq lay nil)
    (COMMAND "-PLOT" "Y" "" "COLOR-PRNA3" "A3" "m"    "LANDSCAPE"	   "N"   "W"  "-6,-6"    "807,560"	"1=2"  "C"
    	       "y"	  "Designlasercolor.ctb" "Y"	"N" "N" "N" "N" "N" "y"      )
    (setq numlay (+ numlay 1))
    ) ; end repeat
    ) ; defun
    (AH:pltlays)
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    FWIW -
    AUTOPUBLISH was implemented in 2009, and can plot to multi-document PDF, and DWF in a relative (to DWFPREFIX), or specified (always the same, i.e., Documents, etc.) path of your choosing.
    Configured to use a named page setup, I simply SAVE* a document, and resultant PDF is produced automagically.
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  5. #5
    Forum Newbie
    AutoCAD 2013
    Oct 2014
    2
    Autopublish does it beautifully, thank you very much
  6. #6
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    You're welcome, YAZ; I'm happy to help.
    FWIW - I also use a custom app to make AUTOPUBLISH only produce electronic documents for exhibits and sheets, and not for DREF/XREF-only drawings... Should that be of interest, see the Exchange link in my signature.
    Cheers
  1. Lisp to plot multiple lines from a text file of start/end coordinates?
    By ktd27 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th May 2014, 04:19 am
  2. AutoCAD 2014 File Tabs
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 17th Jul 2013, 08:47 pm
  3. AutoCAD 2014 File Tabs
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 26th Mar 2013, 05:43 pm
  4. Plot multiple sheet from one file
    By Mick in forum AutoCAD Drawing Management & Output
    Last Post: 9th Sep 2010, 03:59 pm
  5. Plot multiple layers via script
    By pharrold in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 21st Jul 2010, 11:20 am
Tags for this Thread
