Results 1 to 3 of 3
    Super Member
    Sengna's Computer Details
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    524
    Default how to trim corner via sheet metal? Inventor 2014
    What tool can i use to trim something like this on the image in .ipt or sheet metal environment? i was looking something like miter tool in assembly environment but i am not on assembly file. Thanks
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    Well, if modeled correctly, Inventor should have already trimmed that for your.
    But since you already have it modeled, the Corner Seam tool sounds like a likely candidate for investigation.
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 7
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    2TB
    Portable TB drive
    Samsung SyncMaster 226
    Mechanical
    Lazer's Discipline Details
    Design Engineering Manager
    Mechanical
    Mechanical Designer using Autocad and Inventor
    Inventor 2016
    Aug 2005
    Northants, England
    1,817
    Not the best of methods but as you are stick with a model that will not update correctly you could convert it back to a part make the cut then convert it back to sheet metal (not the correct workflow by any means but a way round in this case).
    USING AUTOCAD 2016 AND INVENTOR 2016, ALIAS 2016 SHOWCASE 2016.
    If in doubt scale and don't ask!
  1. Sheet metal design in Inventor
    By zmarcoz in forum Autodesk Inventor
    Last Post: 5th Jul 2013, 10:03 pm
  2. Sheet Metal Corner Seams Error
    By Laurel in forum Autodesk Inventor
    Last Post: 20th Apr 2012, 02:38 pm
  3. Sheet Metal Corner Gap????
    By NeedHelp in forum Autodesk Inventor
    Last Post: 27th Sep 2009, 05:41 am
  4. Inventor 2009 Sheet Metal
    By Lazer in forum Autodesk Inventor
    Last Post: 26th Jun 2008, 08:47 pm
  5. Sheet Metal; Bend a Corner
    By Tjeerd in forum Autodesk Inventor
    Last Post: 5th Apr 2008, 09:45 am
Tags for this Thread
