how to trim corner via sheet metal? Inventor 2014
Sengna
What tool can i use to trim something like this on the image in .ipt or sheet metal environment? i was looking something like miter tool in assembly environment but i am not on assembly file. Thanks
Well, if modeled correctly, Inventor should have already trimmed that for your.
But since you already have it modeled, the Corner Seam tool sounds like a likely candidate for investigation.
  • 1 month later...
Not the best of methods but as you are stick with a model that will not update correctly you could convert it back to a part make the cut then convert it back to sheet metal (not the correct workflow by any means but a way round in this case).
