Book/tutorial recommendations
cadmikee
Hi,
I have the opportunity to use full AutoCAD rather than LT and I want to get back into 3D modelling as I have used Pro-E (several years ago now) and want to get back into it, mainly as 3D printing seems to be taking off and I want to be able to produce prototypes for various applications.
As a 2D user, can anyone suggest a good book or tutorial that I can start with to develop my skills. I favour the type of tutorial that takes you step by step through producing various items, for example, how to create a typical model with through holes, protrusions, fillets etc.
I've heard Lynda dot com is meant to be good for tutorial. worth it?
Anyone have any recommendations other than spending £100's on a training course.
Many Thanks
Mike
What version of full AutoCAD would you be using?
Wouldn't you rather work in Pro-E, or something similar, rather than use AutoCAD? I think you'd be disappointed to some degree.
If you're just starting in 3D with AutoCAD I'd recommend that you become very familiar with the following commands
  • EXTRUDE
  • REGION
  • REVOLVE
  • SLICE
  • SOLIDEDIT
  • 3DFORBIT
There's lots more to discover, but these commands will get you off to a good start doing 3D modeling in AutoCAD.
