Results 1 to 4 of 4
    Full Member
    AutoCAD 2011
    Oct 2012
    36
    Default Attributes from hatch to block.
    Hi
    I have 96 different hatches.
    I have a template block with only 2 lines of text: Area and Name.
    I want this block to appear in the middle(ish) of a hatch when i click on it, with "Name" attribute beeing the layer the hatch is on, and the "Area" attribute of the block is the Area of the hatch, divided by 1000000 and m2 behind it.
    Is this possible?
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, W8 + W8.1 Vista
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    Yes it is using LISP or VBA. On which layer should the block be inserted? Does it have to be a block or would MText be acceptable?
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    Full Member
    AutoCAD 2011
    Oct 2012
    36
    I am running out of time on this project so I have to do it manually, cant afford to use time on automating it and maybe failing.
    Thank you for your help!
  1. Replace block and its attributes with new block and attributes
    By SPACECADET in forum AutoCAD Drawing Management & Output
    Last Post: 8th Mar 2017, 08:43 pm
  2. Rotate block with attributes = messed attributes
    By diego gr in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Jan 2012, 07:34 pm
  3. Object Data (OD) attributes to Block attributes
    By mpozauko in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jan 2012, 01:08 pm
  4. Block Attributes, Creating Attributes
    By CADLee in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Jan 2012, 06:40 pm
  5. Block Attribute answers ability to change block Physical Attributes??
    By Kaidoz in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Mar 2008, 10:25 pm
Tags for this Thread
