dcuddihy Posted October 16, 2014 Share Posted October 16, 2014 I am importing boards from TraxMaker to Inventor using a DXF file as a go between. The odd thing is the legends on the secondary side of the PCB, layer BO-STR, are individually flipped horizontally from the indicator dot. This only affects this one layer and all else is correct. Is it because Inverter sees it as text and wants to display text left to right even though the original image is backwards. (It is on the secondary side of the PCB so it has to be backwards when looking from the Primary side.) What could be causing this and what setting is toggled wrong? Can I make Inventor see it as an image instead of text? How do I fix it or as a work around flipping each one back to what they should be? Regards, -Dan Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 17, 2014 Share Posted October 17, 2014 (edited) I have moved your question to the Inventor forum. Edited October 17, 2014 by Cad64 Quote Link to comment Share on other sites More sharing options...
