3D UCS extrude combination function
hlammerts
I am trying to produce a 3D solid routine that combines a UCS 3 point function in it. The first 3 points control the ucs, the following points should be given by user and a extrude must be made. The last part i cannot get to finish.
defun C:extucs ()
(setq spt1 (getpoint "\nSpecify UCS 1st point"))
(setq spt2 (getpoint "\nSpecify UCS 2nd point"))
(setq spt3 (getpoint "\nSpecify UCS 3rd point"))
(command "ucs" "3" spt1 spt2 spt3)
;;; ?? here i would to get x- amount of points
;;; ?? here to draw a closed pline from these points
(command "pline" pause)
(COMMAND "extrude" "p" pause pause "")) ; extrude this pline
Maybe something like this
(defun c:extucs ( / pt pt_list spt1 spt2 spt3)
 (if (and (setq spt1 (getpoint "\nSpecify UCS 1st point"))
   (while
     (setq pt (getpoint "\nPick point: "))
     (setq pt_list (cons pt pt_list))
   (if pt_list
       (command "_.pline")
       (foreach pt pt_list (command pt))
       (command "_C")
   (command "_.extrude" "_L" "" "\\")
   (command "ucs" "_P")
Hope that helps
Henrique
Hope that helps
Henrique
Nice ! Henrique , when pick point draw pline, I think need displays the line between point and point immediately !
Thank you! Alberto.
I just wrote the code this way, to answer the OP request
';;; ?? here i would to get x- amount of points
;;; ?? here to draw a closed pline from these points'
we could just store the lastent, use the command pline, test if there is a new ent, and if closed, then extrude...
Henrique
Thanks!
The problem i have is the forming of the list
It should be spt1, spt2, (pt - x amount), closing with spt3
And then extude the closed pline
 (if (and (setq spt1 (getpoint "\nPick 1st point (UCS)"))
   (setq spt2 (getpoint "\nPick 2nd point (UCS)"))
          (setq spt3 (getpoint "\nPick 3rd point (UCS)"))
   (grdraw spt1 spt2 6 1)
   (grdraw spt1 spt3 6 1)
   (while
   (if pt_list
       (command "_.pline")
       (command "_C")
Thanks!
You're welcome, hlammerts.
If I understood correctly, perhaps something like this:
(defun c:demo (/ pt pt_list spt1 spt1w spt2 spt2w spt3 spt3w)
     (setq spt1w (trans spt1 1 0)
           spt2w (trans spt2 1 0)
           spt3w (trans spt3 1 0)
     (command "_.pline" (trans spt3w 0 1) (trans spt1w 0 1) (trans spt2w 0 1))
     (while (setq pt (getpoint "\nNext point: "))
       (command pt)
     (command "_C")
Hope that helps
Henrique
