Filter No Good
suryacad
Hi guys.
i get stuck due to this type of problem a lot .
here you see i have filtered a text which is actually cyan color but shows in the filter as 256 - By Layer.
Same goes to any entity be it lines or text which has color set to by layer
and iam unable to filter them by colour.
Ya Spaj i tried Qselect too doesnt help. filter and qselect properties are dependent on layer properties.
RobDraw i have not done anything to override the properties. in layer properties one sets the colour to say red, and the same layer is set to current and while drafting i dont change the properties i keep them set to by layer. it gets the colour alright but on filter insted of showing red it shows 256- by layer.
The text color is not "Cyan"... it's "ByLAYER" So you are effectively filtering them by "color" because your filter will only select objects on the "B-TEXT" layer that have a color property of "BYLAYER" Any texts on that layer that have a Color Property override will not be selected.
