blueinspiron Posted October 18, 2014 Share Posted October 18, 2014 I can't seem to figure out what the dimension is for the big circle on the left that is with the center line. I also have a question on how to input the degrees, minute into autocad instead of regular angles. I never learned that yet. One last question is the x degree at the bottom. Thank you Quote Link to comment Share on other sites More sharing options...
paulmcz Posted October 18, 2014 Share Posted October 18, 2014 Radius of the big circle = 1.5 * sqrt (2) X° = 180 - 20 - 31/60 - 45 - 90 No idea how to enter degrees and minutes Quote Link to comment Share on other sites More sharing options...
nestly Posted October 18, 2014 Share Posted October 18, 2014 Look at the Right Isosceles Triangle that's between the left and right circles. The radius of the left circle is equal to the hypotenuse. so you can either calculate it, or draw it with AutoCAD using lines at 45 degree increments. Re: Degrees/Minutes/Seconds .... 20.5 degrees = 20d30' = 20d30'00" Quote Link to comment Share on other sites More sharing options...
blueinspiron Posted October 19, 2014 Author Share Posted October 19, 2014 Thank you for the help! Quote Link to comment Share on other sites More sharing options...
