nura235 Posted October 20, 2014 Share Posted October 20, 2014 Hi members, I have a following query I have a dwg file with page number which are in format. 1/200 2/200 3/200 .... 200/200 If one of page number deleted in between the above sequence, so I have renumber all pages manually. So is it possible for you excellent guys in programming, which will search for the above sequence and if one of the sequence is missing or not found it will renumber the next page to current one. For e.g. if 2/300 would get deleted, the lisp will search that 2/300 is missing and it will again do seraph if 3/300 is there on dwg file, if yes, it would alot 3/300 to 2/300 and this program will go till end. I hope you will understand. May be you people have some other ideas on this to renumber all pages which are existing on dwg files. Looking forward nura Quote Link to comment Share on other sites More sharing options...
pBe Posted October 20, 2014 Share Posted October 20, 2014 I have a dwg file with page number which are in format. The drawing file name? Text? Attribute? Sheet Set? Quote Link to comment Share on other sites More sharing options...
nura235 Posted October 20, 2014 Author Share Posted October 20, 2014 not required anymore. below link of leemac work for me. http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/batch-find-and-replace-from-an-excel-file/td-p/5161867 Quote Link to comment Share on other sites More sharing options...
pBe Posted October 20, 2014 Share Posted October 20, 2014 Well good for you then. Quote Link to comment Share on other sites More sharing options...
