Chrystian Posted October 21, 2014 Share Posted October 21, 2014 Hi , can someone help me , i am trying to create some solid walls but i'm stuck with this mesage Null solid created - deleted . help please thanks Drawing2.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 21, 2014 Share Posted October 21, 2014 Your objects (a solid within another solid) in the background. The foreground object (mine) is what I think you are trying to achieve is it not? Subtract your inner solid object from the outer solid object and you'll get the same result. Next time create your inner and outer wall profiles then use the PressPull command to give the walls height. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 21, 2014 Share Posted October 21, 2014 (edited) Well? Did you finally achieve the results you were looking for? Yes? No? Not sure? No response? I'll take a wild guess and assume you completed the task successfully. Post back if you have any further 3D modeling related questions. Good luck with your house. Edited October 22, 2014 by ReMark Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 22, 2014 Share Posted October 22, 2014 I moved your thread to the AutoCAD 3D Modelling & Rendering Forum. Quote Link to comment Share on other sites More sharing options...
