Add attribute values
przem_saw
Hi, to everyone.
I was looking the routine everywhere with no success :( witch can in block "bar_1" take two attributes "tag1" and "tag2" multiple the two values and put the result in the same block in "tag3"
Anyone can help ?
Thanks for reply.
I used to do that :)
But unfortunately, currently I'm using a ZwCAD 2014 and for now the program doesn't support mathematical operations in field.
That's why I need move all my calculations into a lisp routine.
The perfect code will have an easy settings in the beginning like block name, tag and clear idea how to make calculation to make it more universal.
I attached an example of basic idea.
example.dwg
  • 2 weeks later...
Thanks to Lee Mac website I made this:
I used diferent attributes names but it is easy to change now
;;ver 1.0
;; cfany 2014.10.31
(defun c:re3 ( / )
(regen3)
(defun regen3 ( / idx lst2 ss1 zas roz mno dod ile zas_o roz_o mno_o dod_o )
   (if
       (and
           (setq ss1 (ssget "X" '((0 . "INSERT") (2 . "BAR_T2") (66 . 1))));only  BAR_T2 blcks
	   (setq zas "ZASIEG"
			 roz "ROZ"
			 mno "MNOZNIK"
			 dod "DODATKOWY"
			 ile "BAM")
		(repeat (setq idx (sslength ss1))
				(setq idx (1- idx))
				(setq bname (ssname ss1 idx))
		;			 (princ idx) (princ bname)
           (setq zas_o (LM:getattributevalue bname zas))
		(setq roz_o (LM:getattributevalue bname roz))
		(setq mno_o (LM:getattributevalue bname mno))
		(setq dod_o (LM:getattributevalue bname dod))
		(setq lst2 (itoa (* (+ (/ (atoi zas_o) (atoi roz_o)) (atoi dod_o)) (atoi mno_o))))
		(LM:setattributevalue bname ile lst2)
		;		(princ zas)	(princ "\n")
   (princ "\nZaktualizowano")
;; Set Attribute Value  -  Lee Mac
;; Sets the value of the first attribute with the given tag found within the block, if present.
;; blk - [ent] Block (Insert) Entity Name
;; tag - [str] Attribute TagString
;; val - [str] Attribute Value
;; Returns: [str] Attribute value if successful, else nil.
(defun LM:setattributevalue ( blk tag val / enx )
   (if (= "ATTRIB" (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk)))))))
       (if (= (strcase tag) (strcase (cdr (assoc 2 enx))))
           (if (entmod (subst (cons 1 val) (assoc 1 enx) enx))
                   (entupd blk)
                   val
           (LM:setattributevalue blk tag val)
;; Get Attribute Value  -  Lee Mac
;; Returns the value held by the specified tag within the supplied block, if present.
;; Returns: [str] Attribute value, else nil if tag is not found.
(defun LM:getattributevalue ( blk tag / enx )
           (cdr (assoc 1 enx))
           (LM:getattributevalue blk tag)
