Sharing! AutoStartup
AIberto
Source from : bbs.xdcad.org , by st788796
(defun XD::AutoStartup (path tf / Profiles allpro newnum AutoLoadpath)
 (vl-load-com)
 (if tf
     (vla-getallprofilenames
(vla-get-profiles
  (vla-get-preferences (vlax-get-acad-object))
'Profiles
     (setq allpro (safearray-value Profiles))
   (setq allpro (list (getvar "cprofile")))
 (setenv "ACAD"
  (strcat (getenv "ACAD") ";" (vl-filename-directory path))
 (if (wcmatch (getvar "acadver") "19.[1-9]*")
   (if tf
     (mapcar '(lambda (x / trpath)
  (setq trpath (strcat
   "HKEY_CURRENT_USER\\"
   (vlax-product-key)
   "\\Profiles\\"
   x
   "\\Variables"
  (vl-registry-write
    trpath
    "Trustedpaths"
    (strcat (vl-registry-read trpath "Trustedpaths")
      allpro
     (setvar "TRUSTEDPATHS"
      (strcat (getvar "TRUSTEDPATHS")
 (mapcar '(lambda (x)
     (setq AppLoadPath
     (strcat
       (vlax-product-key)
       "\\Profiles\\"
       x
       "\\Dialogs\\Appload\\Startup"
     (setq
       NewNum
 (itoa
   (1+ (read
  (vl-registry-read AppLoadPath "NumStartup")
     (vl-registry-write AppLoadPath "NumStartup" NewNum)
     (vl-registry-write
       AppLoadPath
       (strcat NewNum "Startup")
       path
  allpro
