Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2011
    Oct 2014
    5
    Default publish PDF - name of PDF's
    hello
    i'm priting my drafts with PUBLISH to a PDF file
    i'would like to change the name of the PDF : the name would start by the name of the tab and finish by the name of the file
    How can i lmake this possible?
    Phil
    PS : sorry, i need to increase my Acad vocabulary in english which is quite poor yet (i'm working on a French version)
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,781
    On the publish dialog, click publish options, click the naming line and select "Prompt for name". Then, before the file is saved to the folder, you will see a dialog where you can type in a pdf file name to save it as.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by philsogood View Post
    hello
    You did fine. Better than some who only know English.
    Drafting is a breeze.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,124
    Quote Originally Posted by Dana W View Post
    I believe that is opposite of what the OP wants. That would be manually entering the name for each sheet.
    If you select "Specify Name" it will name the files with no input from user, but, it names them <Drawing File Name>-<Layout Tab Name> and I believe you want <Layout Tab Name>-<Drawing File Name>.
    If the default order is not acceptable, I believe you will need a LISP solution, find another PDF Plotter that allows to set up automatic naming or as Dana W points out, manually enter the names.
  5. #5
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,781
    Philsogood, (what the h*ll does that mean?) If you had not said something, I'd have never known that English is not your first language. I studied French for 4 years in school, and I still have no clue. Personally, I think that having to learn the French language is why the French people start drinking wine at such a young age.
    Quote Originally Posted by SLW210 View Post
    No, it's manually entering the name for each File, or sheet, depending on the multi-sheet file option. That is the best there is for custom publish(ed) file names without a lisp program, like you said. I didn't see any indication that the process needed to be automated. Of course, me not working in a mass production environment, I don't reflexively think that way.
    (And the whole process is a bit more clearly laid out.)
    One thing to think about is that putting the layout name first will make the files sort weird in the directory view. If one is keeping many backup copies of these pdf files(which I do), they should sort by Project/Drawing name, then layout name.
    As a sub-contractor, I would not dare ship out a CAD file without also keeping a copy of the pdf file as I submitted, plot stamped with username, time, and date.
    Twice in the last five years, with two different (once only) clients, I have had to prove who changed a dwg file last, so I could get my money for a drawing I did NOT break.
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Stating the obvious here but that would depend on the layout name. It could be that the OP has already implemented the naming convention and is happy with it. Now, he wants to automate it.
    Aren't there file re-naming utilities that could help with this?
  7. #7
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,781
    Quote Originally Posted by RobDraw View Post
    Yeah, I am sure it is already set up the way the OP wants it. Just sayin'. You mean the whole world doesn't name the layouts, One, Two, Three, Four, etc.?
    It would help if the OP would mention something about Automation of the process. I never did get that.
  8. #8
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    It's not stated but inferred from the the fact that he is using publish. Why would he ask about renaming manually?
  9. #9
    Forum Newbie
    AutoCAD 2011
    Oct 2014
    5
    hi
    sorry for being so late to anwer i had differents tasks to do before
    yes my layout are numbers which are the number of the draw 001... 151... with the "indice" of the draw A, B... C2...
    unfortunately i do not know lisp enough to be able to create a program to do a such thing... (i a lisp professional with (command)!! )
    thanks for your advicess
    Phil
  1. Publish
    By dbroada in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2009, 08:34 am
  2. Publish
    By Alan Cullen in forum AutoCAD Drawing Management & Output
    Last Post: 7th May 2008, 10:54 am
  3. Publish
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 6th Nov 2007, 07:38 pm
  4. how to publish PDF
    By PIAPPLE in forum AutoCAD Beginners' Area
    Last Post: 28th Aug 2007, 06:50 pm
  5. Publish
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jun 2007, 03:09 pm
Tags for this Thread
