how to explode MInsert Block
ramale
Measure and note down the spacing between those instances (rows, respectively columns), mark the location of the reference point (that it, insertion point of the group) and use it to re-insert the block (use INSERT command this time). This is possible since its definition exists in drawing’s database. Next step EXPLODE it and use ARRAY command to recreate the group.
This article by AutoDesk explains a work-around to your dilemma.
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Blocks-inserted-using-MINSERT-cannot-be-exploded.html?v=2013
Or you can try Jeffery Sanders lisp routine called XMINSERT.LSP which can be found here....
http://www.jefferypsanders.com/autolisp.html
The download is free.
